ISM-SRE-300 Upgrade CUE 7.1.5 to 8.0.1 failed now stuck in boot loader
Mar 29th, 2010
Did a SRE upgrade to Unity Express 8.0.1, stuck at boot loader. Curl error code is 78.  See log attached.
Any idea what Curl error code 78 is and how to fix it?
joemccann Mon, 04/26/2010 - 11:21
Having the same issue.  Did you ever get this resolved?  If so, what was the fix?
Jason Aarons Tue, 04/27/2010 - 05:02
Check the logs on your tftp server, mine wasn't running . Too bad the error message wasn't more descriptive, eh?
I also put the tftp server on the same Layer2 segment. Used tftpd32.exe on TACs recommendation.
Related Content
