Active-Active config from N5k to N2k
Answered Question
Mar 29th, 2010
  • Bronze, 100 points or more
On the N5k-B set at priority 105, I cannot see interface 101 of the fex, but can see inter 101 on "priority 110, n5k-A" why is that? when I do a sh vpc brief, adj is up alive. I went ahead and powerdown the N5k-A and now N5k-B has inter 101....so can I assum this is normal behavior?
vpc domain 200
  role priority 105 while the other N5k is set to 110
  peer-keepalive destination 192.168.1.1
  peer-config-check-bypass
fex 101
  pinning max-links 1
  description FEX0101
interface port-channel101
  description ****TO-N2K-ROW-1****
  switchport mode fex-fabric
  untagged cos 0
  fex associate 101
  speed 10000
interface Ethernet1/7
  fex associate 101
  channel-group 101
interface Ethernet1/8
  fex associate 101
  channel-group 101
Correct Answer by allan.thomas about 7 years 4 months ago
If you are looking at configuring the N2K for so that both uplink are active-active toward the vPC peer devices, then you need to configure the interface port-channel 101 with a common vPC identifier.  For example configure both interface port-channel 101 on the N5Ks to be in say 'vpc 101', without this they are not logically bound.
If you run a 'show interface fex' or 'show fex' not sure from the top of my head, but it should show the status of the fex in question from the N5K which you are unable to see the interface.
Allan.
Hope this helps, pls rate helpful posts.
Overall Rating: 5 (2 ratings)
Correct Answer
allan.thomas Mon, 03/29/2010 - 16:18
  • Blue, 1500 points or more
Allan.
