TCP/UDP ports used by MTP router
Mar 29th, 2010
If any one knows kindly provide the me the TCP/UDP ports used by MTP router. I require this for firewall acess.
I have below information with me. Is this correct or need to add more?
GatewayUCM47,50,51Generic Routing Encapsulation (GRE), Encapsulating Security Payload (ESP), Authentication Header (AH). These protocols numbers carry encrypted IPSec traffic. They do not constitute a port as indicated in the column heading.
UCMGateway
GatewayUCM500/UDPInternet Key Exchange (IKE) for IP Security protocol (IPSec) establishment
UCMGateway
GatewayUnified CM (TFTP)69, then Ephemeral / UDPTrivial File Transfer Protocol (TFTP)
GatewayUCMEphemeral / UDPH.245 signaling services for establishing voice, video, and data
UCMGateway
GatewayUCM2000 / TCPSkinny Client Control Protocol (SCCP)
GatewayUCM16384 - 32767 / UDPReal-Time Protocol (RTP), Secure Real-Time Protocol (SRTP)
UCMGateway
IP VMSIP-Phone16384 - 32767 / UDPReal-Time Protocol (RTP), Secure Real-Time Protocol (SRTP)
IP-PhoneIP VMS
Thanks in advance
Pushkar
pushkar.parnaik Tue, 03/30/2010 - 08:13
Hi David,
Thanks for your reply. Here hardware MTP means we have cisco 2811 router which we are using for a Media Termination Point.
We require a port information between IP-Phone to MTP, MTP to Voice Gateway and MTP to callmanager.
Pushkar
david.macias Tue, 03/30/2010 - 20:02
I know what an MTP is, but thank you for the explanation.  However, considering you're in the contact center section I assumed you would be talking about either UCCE or UCCX, try the IPT forum you might have better luck there.
david
