Cisco 2010P Questions
Mar 29th, 2010
Hi all,
I have just purchased the Cisco 2010P-G5 Small business switch.
Questions:
Ø  Does this switch support / work with the Cisco call manager and the Cisco Phones
Ø  Can you automatically backup the config e.eg daily.
Many Thanks
Glenn Quesenberry Tue, 03/30/2010 - 07:05
  • Cisco Employee,
Gary,
     So you've purchased an SFE or SGE Small Business Switch.  To answer your questions in order:
1.  The SFE or SGE series is a Small Business Switch supported by the Small Business Support Center (SBSC) not traditional Cisco TAC.  Communications Manager on the other hand is a TAC supported product, so as you can see the first issue is with two separate support teams.  Also the SFE/SGE switches are not configured or managed with the same tools as traditional Cisco gear and are not IOS or CLI based.  The SFE/SGE switches are not designed to fully integrate with Communications Manager; however you could very well likely get it working (they are 802.3af standards based PoE); but the other broader issues identified above should help you understand that's not a best practice.
2.  As far as automatically backing up the configuration, there's not a built-in feature to do that if that's what you're asking about.  You can run dual images on those switches however.
Hope this helps!
Glenn
