How to install a backup on CUCM 6?
Mar 30th, 2010
I have just upgraded my CUCM from 6.1(4) to 6.1(5) (oh and the inactive partition is every old version of 6.1(3) but there has been a bit of an issue and I need roll back to a pervious version backup.
Thing is all my backup are from version 6.1(4), Therefore can I install the backup from CUCM 6.1(4) straight on to CUCM 6.1.(5) or to I have to downgarde back to version 6.1(4) before I install the backup?
Cheers for any help
Aaron Harrison Tue, 03/30/2010 - 01:38
  • Community Spotlight Award,
    Member's Choice, May 2015
You need to restore to the exact version that you backed up from.
Also best to keep your problem in one thread with an accurate description of what you've done rather than open a load of separate ones.
Aaron
Related Content
