03-30-2010 01:48 AM - edited 03-06-2019 10:22 AM
Hello
I am planning to build our network
We have 3 branch and the headquarter (the number of branch will grouth)
Each branch should be connected to the headquarter with VPN link (ipsec 3des)
I have one cisco 2821 for the headquarter and one cisco 2801 for each branch
I would also implement voice on my network, Cisco call manager express should be installed on the cisco 2821 and should manage all VoIP call on our network.(branch + head quarter). All cisco Ip phone are in DHCP mode and DHCP server for Ip phone is the cisco 2821
Computer can be either in DHCP or static mode, dhcp server for computer is the local router on each LAN
I use the catalyst 2960 on the headquarter to aggregate vpn conexion (vlan 80) and headquarter LAN traffic (voice vlan 10 and data vlan 20)
The Cisco 2821 router should also serves as my gateway to the Internet
And I have several servers on my network.
Users who are outside of our offices should also access these servers from the Internet,
This access should be secured, user could use free integrated windows vpn client or cisco vpn client
These users use Windows XP or vista and Internet Explorer.
I would use access list on each router to give or block access to internet, I would have 2 group of user on each site (with or without access to internet)
Now I have
cisco2821-sec/k9
cisco2801-hsec/k9
I would upgrade the cisco 2821 ios to advance IP service and install CME (the last version)
Could you have a look on my architecture and tell me if my network plan is good ?
Do you think that everything should work ?
Have I missed some thing ?
Please advice
Thanks in advance
03-30-2010 04:56 AM
Hello
Now I have
cisco2821-sec/k9
cisco2801-hsec/k9
Please advice
Thanks in advance
Design seems to be simple but my concerns are what about the firewall in your network,I would suggest the traffic which is coming and from outside and going from inside and the traffic which are getting landed from branches need to be scanned via firewall,so you should have firewall in your network.
and if you see you have single point of failure at two one at router level and anothere at switch level,if client has budget to purchase then ask him too have redundacny setup at least at these two levels.
Another concern what is the isp bandwidth and branch bandwidth which will be using voice and data also,you should have done bandwidth budgetting with futrue in concern.As voice traffice require good amount of traffic and possible implement qos also to piroritize the voice traffic in network.
Hope to Help !!
Ganesh.H
Cisco will donate $1 to the Red Cross Haiti fund for every rated post!
https://supportforums.cisco.com/docs/DOC-8727
03-30-2010 04:59 AM
Just curious, but why are all of your branch office WAN connections in the same subnet?
03-30-2010 07:19 AM
Each branch is directly connected to the headquarter using wireless link. I already installed the 3 radio link, so there is no ISP between branch and headquarter and there is no bandwith problem between branch and headquarter
The only ISP is the one who give the internet connexion
Please advice
Thanks in advance
