03-30-2010 02:20 AM
I am using ASA version 7.2 . Using AAA for authentication.
When using complex passphrases password more than 15 characters. The password is not accepted on VPN client and gives error "Connection terminated by peer Reason 433: Reason not specified by peer".
Any clue?
Walid Mahdy
03-30-2010 03:18 AM
Hi Walid,
Are you using local ASA database for authentication?
If yes, the maximum is only 16 characters.
Here is the URL for your reference:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/uz.html#wp1568449
Hope that helps.
03-30-2010 03:27 AM
Hi Halijenn,
Thanks for your reply,
Actually, I am not using local authentication, I am using AAA server for clients authentication.
And it is working fine up to 15 characters.
03-30-2010 03:32 AM
If you use the "test aaa-server" command to test the username/password, are you able to authenticate successfully with password more than 15 characters?
Also what version of ASA are you running?
03-30-2010 03:52 AM
I tried to do test aaa-authentication with 20 chr. But it gave me ...
ERROR: Authentication Server not responding: No error
Walid
03-30-2010 04:57 AM
Well, in that case, your AAA server maybe does not support more than 15 characters.
