Question on 1841 IOS
Mar 30th, 2010
My 1841 router is loaded with IOS (C1841-IPBASE-M), Version 12.4(1c) and the Flash size is 32Mb. According to our ISP technical support the router cannot be configured for BGP session because the IOS version does not support it. What version is just right? What do I need to do? The free space on the Flash is 15839232 bytes.
Thank you.
Jon Marshall Tue, 03/30/2010 - 04:02
John
Feature Navigator is the tool you need to use for this. If you click on the link below it will take you to the start page. From there choose "Search by plaform" and then select your device and choose a feature set. Note that IP Base does not support BGP but there are a number of feature sets that do so you can choose the one you want. It will also show the image once you have chosen the feature set and the amount of flash/DRAM required to run it.
Feature Navigator
If you have any more queries please come back.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
joertenazas Tue, 03/30/2010 - 18:08
Hi Jon,
Thank you. My problem now is the free space of the Flash, I have to replace it with 64K.
More power!
Jon Marshall Wed, 03/31/2010 - 02:27
joertenazas wrote:
Hi Jon,
More power!
There were IOS images with BGP that only needed 32Mb flash but you would need to delete the old file first so you don't necessarily have to upgrade your flash.
Jon
Related Content
