Connecting to Router through Modem & AUX port but can't type
Mar 30th, 2010
Hi all
I am having an issue with connecting to a Cisco 7201 via the AUX port through a modem. The modem is plugged into the AUX port and I am dialing into the modem, everything seems to be working fine as I get a login prompt and my banner etc but I can't type anytihng. If I type then nothings happens... If I just type a bunch of random characters on the keyboard then when the authentication prompt times out and it goes back to the username, it will show a few of those characters.. I have tried many things, changing speeds etc, I have even tried changing modems and it is doing the exact same thing. Any help appreciated.
Here is my config:
line aux 0
exec-timeout 2 0
modem Dialin
transport input all
stopbits 1
speed 115200
flowcontrol hardware
I have searched on here and found people having similar problems but no solutions. I have tried this one a Cisco 2821 with the same config and it works with no problem, the only difference is the phone line is different.
Help!
Overall Rating: 5 (1 ratings)
Ganesh Hariharan Tue, 03/30/2010 - 05:05
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi all
Here is my config:
line aux 0
exec-timeout 2 0
modem Dialin
transport input all
stopbits 1
speed 115200
Help!
Check out the below links hope that helps.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a008009428b.shtml
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094bbc.shtml
Ganesh.H
Cisco will donate $1 to  the Red Cross Haiti fund for every rated post!
https://supportforums.cisco.com/docs/DOC-8727
markjoyner Tue, 03/30/2010 - 05:47
Thank you for the articles, I did find those and tried what it mentions in there but have had no luck.
Giuseppe Larosa Tue, 03/30/2010 - 05:59
  • Hall of Fame,
    Founding Member
Hello Mark,
>> speed 115200
how can you use this speed with a dialup modem (max 56 kbps in one direction CO to user, 33 kbps user to CO )?
you need to use a slower speed for sure
Hope to help
Giuseppe
markjoyner Tue, 03/30/2010 - 06:33
Hi Giuseppe
thanks for the response, I did try setting the speed to 9600 and also 33400 and none of those worked. I set it back to 33400 now and tried it again and it is still doing the exact same thing.. I was under the impression that the aux speed was only the speed of the communications between the modem and the router, not the actual dial up speed.
Mark
Giuseppe Larosa Tue, 03/30/2010 - 06:41
  • Hall of Fame,
    Founding Member
Hello Mark,
that is correct however I would use a slower speed
I will review your attached config with more attention
Edit:
some commands may be missing have a look at
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080093c76.shtml
modem inout
exec-timeout 0 0
and some AT commands have to sent to the modem via the AUX port, a chat script can be used for this part
Hope to help
Giuseppe
markjoyner Wed, 03/31/2010 - 02:01
Thanks Giuseppe
I will have a look at the articles and see if I can find something.
Mark
markjoyner Wed, 03/14/2012 - 08:30
If this helps anybody, I managed to find the solutuion to this problem. The issue was a bug with IOS 12.4(24)T2 and 7201 routers. Cisco recognised there was an issue and created a bug ID for it, the ID is: CSCtj27898. they fixed the issue in later IOS releases.
Related Content
