Dynagen on real Network
Mar 30th, 2010
I have a problem with a dynamips/dynagen  topology.
I have build a real network based on 28xx Router. To complete the  plateform I have to connect a 7200 Cisco Router (using emulation because  I don't have materiel).
With different method I tried to connect them like that :
Quote:
# Simple lab test 7200 PE
[localhost]
# image = \Program  Files\Dynamips\images\c7200-jk9o3s-mz.124-7a.image
# On Linux / Unix use forward slashes:
image = /opt/dynamips/images/c7200-adventerprisek9-mz.124-24.T2.bin
npe = npe-400
ram = 256
slot1 = PA-FE-TX
f0/0 = NIO_gen_eth:eth1
The aim is to 7200 interface fa 0/0 and interface to a real Router 28xx  are on the same subnet and dialog without errors.
It not works !! Have you any Idea ??
Using FEDORA
Ganesh Hariharan Tue, 03/30/2010 - 05:12
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
[localhost]
npe = npe-400
ram = 256
slot1 = PA-FE-TX
Using FEDORA
Check out the below link for dynagen to connect with real network.
http://netguide.sakura.ne.jp/dynamips/english/real-network.html
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
Cisco will donate $1 to  the Red Cross Haiti fund for every rated post!
https://supportforums.cisco.com/docs/DOC-8727
Maxime.chevet01_2 Tue, 03/30/2010 - 05:38
ok I understand but I use FEDORA so Linux System. It not the same thing about the descriptor !!
Moreover, He doesn't explain his ip configuration !! do you think he put a static IP address ??
Maxime.chevet01_2 Tue, 03/30/2010 - 11:04
Problem solve :
the config in the .net is not with ''gen'' but ''linux''.
So it is like that :
f0/0 = NIO_linux_eth:eth1
Maxime.chevet01_2 Tue, 03/30/2010 - 11:05
Problem solve :
