What is the impact of disabling xlate in FWSM
Answered Question
Mar 30th, 2010
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi All,
We have simple setup with 3 to 4 zones in FWSM with simple ip traffic flowing across the zones and no natting is configured also in the FWSM.I would like to know what would be the impact if we disable xlate in global configuration in FWSM and what is the command to do the same.
Is there any default count stored for xlate table in FWSM and what happens when we do clear xlate in FWSM.
Ganesh.H
Correct Answer by Jennifer Halim about 7 years 3 months ago
Eventhough there is no NAT configured, it still creates the xlate entry in the xlate table. That is why the "xlate-bypass" feature is useful in this case, to surpress the creation of the xlate in the fwsm hardware so it does not hit the hardware limitation withini the fwsm. There is no impact at all to the production traffic.
This feature is only available in fwsm because it's processed in hardware, whereas ASA or PIX firewall process the xlate in software.
Hope that answers your question.
Overall Rating: 5 (2 ratings)
Jon Marshall Tue, 03/30/2010 - 05:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
ganeshh.iyer wrote:
Hi All,
Ganesh.H
Ganesh
The xlate table is used for NAT translations. If you are not doing any Natting then there won't be any entries in the xlate table. I'm not aware of a way to disable xlate on the FWSM but i'm not sure why you would want or need to do that anyway.
Not sure what you mean by default count, do you mean maximum number of allowed xlate entries ?
If you clear xlate on the FWSM or ASA then any existing connections that have entries in the xlate table will be torn down so it's not usually a thing you want to do during production hours. Note that the clear xlate command has an option to specify which actual xlate entry you want to remove.
Jon
Jon Marshall Tue, 03/30/2010 - 06:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
halijenn wrote:
If you don't need translation, you can configure the "xlate-bypass" feature:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/command/reference/uw.html#wp1306953
The maximum concurrent xlate in FWSM hardware is 262144
Hope that helps.
I stand corrected. Many thanks for that link.
Ganesh - apologies for the misleading information, i have learnt something new today.
Jon
Ganesh Hariharan Thu, 04/01/2010 - 01:08
Hi All,
Ganesh.H
Guys,
Sorry for delay responce and thanks for suggestion and link,Just one query if there is no nat is configured between the zones then as per my understanding show xlate count should be zero is that right ?
But in my case i used to see good amount of count when ever i issue show xlate and if i issue a command for by pass the xlate what will be the impact on the traffic which is passing through firewall.
Ganesh.H
Correct Answer
Jennifer Halim Thu, 04/01/2010 - 02:04
  • Cisco Employee,
Ganesh Hariharan Thu, 04/01/2010 - 02:09
That Great !! Thanks for the confirmation..
Ganesh.H
Kureli Sankar Tue, 11/16/2010 - 11:30
  • Cisco Employee,
Ganesh,
Pardon me for writing on this thread that has already been answered.  One of our customer's pointed out this link to me and asked a bunch of questions.  I thought I will list them here so, everyone who reads this thread would benefit from that.
A good % of our customers who implement this feature xlate-bypass are the ones who try to protect the internet!!  As bad as it sounds, it is true.  Due to bad design or other reasons they tend to have the internet on the higher security level than the other interfaces.  In this case xlate is built for each internet host/IP since it lives on the higher security interface.  Quickly the max xlates (261K) is reached and run into issues where no more translation can be created. http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/specs_f.html#wp1056716
Although, this command xlate-bypass is going to help them whereby we just do not create any translations or show them in the table, this design needs to be addressed and corrected if possible.
Also, the following should be true in order to enable this command:
- no nat-control should be enabled
- nat/global should not be configured
- static - even identity should not be configured
Also, there comes other questions - if the firewall really doesn't have to populate these xlates in the table, why wasn't this the default from the begining when the above conditions are true?
1. Well, this command was only introduced in 3.2.1, I believe only then we started to hear about running the limitation of the total xlates in the box or one context consuming all the xlates due to the fact the internet is on the inside or due to infected hosts or other reasons.
2. Also, sunrpc inpsection is not possible when xlate-bypass is implemented. This is documented here: http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtc54367
Symptom:
This is a documentation bug to get the documentation updated to indicate that
the 'inspect sunrpc' feature is not compatible with the xlate-bypass feature
present in FWSM code version 3.2 and later. The two features cannot co-exist as
the sunrpc inspection relies on xlates for functionality and xlate bypass may
prevent the inspection from functioning correctly.
Conditions:
This condition is present in FWSM code version 3.2 and later where xlate bypass
was first introduced.
Further problem description:
Where xlate-bypass is configured, remove sunrpc inspection and make sure to
allow permission for sunrpc traffic via acl as the inspection will not work and
open pinholes.
3. Besides that, some companies are required to document xlate build and teardown syslog messages (305010  and 305011) for audit purposes which will not be created when implemented.
4. sharing interfaces is very common with FWSM implementation in multiple context mode. Translation is a requirement in this case.
-KS
Juraj Podhajecky Tue, 09/13/2011 - 03:17
Hi KS,
not sure if I understood correctly, but following seems not to be true:
You can have NAT/STATIC/GLOBAL configured together with "xlate bypass" (we use it and it is working fine). This command disables NAT sessions ONLY for untranslated traffic. You will see entries in xlate table for translated traffic, which means that following is also not true
Regarding point 1
You can easily get out of xlates in service provide environment. Imagine that you have 100 contexts on FWSM. I guess this command was introduced to overcome this limitations.
FWSM# sh resource usage summary | i Res|Xla
Resource              Current         Peak      Limit        Denied Context
Xlates                  88891       168870     262144(S)          0 Summary
FWSM# sh context count
Total active Security Contexts: 79
BR
Juraj
Kureli Sankar Tue, 09/13/2011 - 06:12
  • Cisco Employee,
Juraj,
May be I should have added a little more detail that we are talking about same source and destination IP.
You  cannot enable x-late bypass and expect it to "NOT SHOW" the xlates when  you have nat 0 with acl, nat/global or static identity configured for  the same src/dst combo between the same two interfaces.
Yes, xlate-bypass was introduced only in 3.2.1 to  mitigate running the xlate-limit issue.  I believe around the time is  when we saw many cases where the unit  exhausted all 256K xlate count.
-KS
jgunawardhana Mon, 09/26/2011 - 20:03
Hi KS,
I also have some issue with xlate on our FWSM and thought that I will check it on this thread. we get lot of error messages on our firewall saying "%FWSM-3-305006: regular translation creation failed for icmp" although the resource limit has not exceded show below
fw01/act# sh resource usage summary resource Xlates
Xlates                    815         5838  unlimited             0 System
we are running FWSM Firewall Version 4.0(5). Do you know whether this is a bug. any how to get around with this I thought of configuring "xlate-bypass" on the firewall. my question is when I do that will it drop the exisitng connections and re-establish or there wont be any effect on the exisitng connections. I just want to make sure whether i have to arrange a outage in the production networks to implement this
janaki
Kureli Sankar Mon, 09/26/2011 - 21:03
  • Cisco Employee,
It could be this defect resolved in 4.0.9 or above..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCta74788
I listed x-late bypass as a workaround for this problem.
Now if there are xlates that are in the table then it will continue using that.
So, once the command it implemented it is a good idea to issue "clear xlate" - which will clear all connections and xlates through the box. So, yes, downtime scheduling will be a good idea.
-KS
We have dynamic NAT configured from inside to outside interface, but still it is showing NAT entry as below.
"NAT from inside:177.26.99.10 to outside:177.26.99.10 flags Ii"
Expected NAT entry should as below :
"NAT from inside:177.26.99.10 to outside:111.111.111.111 flags Ii"
Can you please explain this behaviour, and suggest if xlate-bypass can help here. We were considering implementing "ip verify revert-path" .Hence here i am thinking whether xlate-bypass is the issue here and implementing same with "ip verify revert-path" woud be a good idea.
