Port-Security violation
Mar 30th, 2010
Hi all,
I'm sending syslog messages from some access switches to CiscoWorks's syslog server. CiscoWorks is installed on a Windows 2003 machine.
I can see %PORT_SECURITY-2-PSECURE_VIOLATION messages in the syslog.log file (located in C:\Program Files\CSCOpx\log\),
but the messages do no appear in the RME \ Syslog Analyzer Severity Level Summary Report.
Are there some variables/options that I must set/check in order to get the port-security violation (severity=2) messages included in the report?
Thanks for any hints!
