BGP Path selection
Mar 30th, 2010
  • Gold, 750 points or more
Below is the output for a WAN router peering with provider external Ebgp and also have iBGP peering as well.
Based on the output below i am assuming that best path is the internal ibgp peer since it looks like the provider (ebgp 213.121.150.121 AS 3854) is doing AS Prepending ( sending Community: 2856:10 2856:104 5400:3001 5400:3002 5400:3300 to us).  So by design bgp will look at lower AS-Path instead and will choose the internal. Without the prepending, then the ebgp will be the prefered of course.
(Site 1)
bgprouter1#sh ip bgp 24.37.192.0
BGP routing table entry for 24.37.192.0/18, version 142343011
Paths: (3 available, best #3, table Default-IP-Routing-Table)
  Not advertised to any peer
  3854 5400 5769
    213.131.18.12 from 213.131.18.12 (195.99.125.167)
      Origin IGP, metric 10, localpref 100, valid, external
   1478 5769  (This via another ibgp nei)
    192.168.45.88 (metric 3) from 192.168.45.88 (192.168.45.88)
      Origin IGP, metric 4294967294, localpref 100, valid, internal, best
Francisco.
Giuseppe Larosa Tue, 03/30/2010 - 06:04
  • Hall of Fame,
    Founding Member
Hello Francisco,
the two AS paths are:
3854 5400 5769
1478 5769
shortest AS path wins so second path is best as it could be expected rightmost AS number is the same (this is the prefix owner)
this is not part of AS path and so it cannot be seen as AS path prepending, these are just multiple BGP communites applied to the route by this ISP
Hope to help
Giuseppe
Cisco will donate $1 to  the Red Cross Haiti fund for every rated post!
https://supportforums.cisco.com/docs/DOC-8727
