Untagged VLAN on Trunk Port - help please
Mar 30th, 2010
Hi folks.
I need to configure a port on a 3750E to support the following:
The port will connect to an Outreach Quad switch, and on the switch I will have 1 x 1130 LAP and on IP device. The Outereach switch is apparantly invisible to VLANS, and will forward both tagged and untagged traffic.
I need the port on the 3759 to accept traffic from the AP and allocate it to one VLAN and allocat the other IP device to another VLAN.
I am looking at sub interfaces (  the 3750 does not support them, i don't thnk) or SVI, or some other methid.
Please would anyone help and advise.
Many thanks,
NM
Giuseppe Larosa Tue, 03/30/2010 - 06:14
  • Hall of Fame,
    Founding Member
Hello Neil,
unless the IP device can be configured to use a vlan tag (for example this happens wit VMware instances) both devices will be in the native vlan.
you cannot use subinterfaces on the C3750 so probably your only way to accomodate IP addresses in two different IP subnets is to use ip address secondary under an SVI interface
interface vlan 1
ip address 10.10.10.1 255.255.255.0
ip address 10.10.20.1 255.255.255.0 secondary
this can do the trick
Hope to help
Giuseppe
Cisco will donate $1 to  the Red Cross Haiti fund for every rated post!
https://supportforums.cisco.com/docs/DOC-8727
