Advanced Device Mobility
Mar 30th, 2010
Can anyone tell me what this means: "DbMobility: can't find remdest  59854154"
This is a SDI trace entry, and I don´t know what thes mean.
thx a lot
David Hailey Fri, 04/02/2010 - 06:34
This is saying that the Remote Destination 59854154 cannot be found or cannot be dialed given the current digit strings.  Is this a valid dial string for your cluster?
Please rate helpful posts!
andspecht Mon, 04/19/2010 - 18:34
Hi Did you find out what this means by any chance?  I'm having the same issue on a trunk between two callmanagers.
Thank you
