03-30-2010 06:55 AM - edited 03-09-2019 10:53 PM
i heard about CSA MC 6.0 high Availability solution, but we can't realize it.
Is it possible to make a reserve CSA server, we are planning to use it in branch office?
Thank you
03-30-2010 06:33 PM
Here is the white paper on CSA MC 6.0.1 High Availability for your reference:
Hope that helps.
03-31-2010 05:57 AM
Thank, but this is not acceptable, its too rich.
Will it work:
I will make a backup of a main server, and then restore this backup on a reserve csa server.
So on the reserve server i will have all information from main server, server names are the same, ip addresses are the same.
I thought that agents wil connect without any problems, but they dont.
ailed transaction, url=https://csa-mc:5401/csamc60/agent, curlerr=60 (SSL certificate problem, verify that the CA cert is OK). Check if agent and CSAMC system times are totally unsynchronized. Or you can use a browser to open the certificate file (sslca.crt) and see if the 'Valid From' date-time of the certificate is later than this host system date-time. Adjust the system time to fix it.
237: testarm1: Mar 31 2010 16:33:23.781 +0400: %CSA-4-MC_NOT_REACHABLE: %[Component=Csamanager][PID=1136]: conn_check: Failed to reach mgmtserver csa-mc:5401 via HTTPS. Will try again in 9 secs
238: testarm1: Mar 31 2010 16:33:32.812 +0400: %CSA-4-AGENT_CURL_ERROR: %[Component=Csamanager][PID=1136]: Failed transaction, url=https://csa-mc:443/csamc60/agent, curlerr=60 (SSL certificate problem, verify that the CA cert is OK). Check if agent and CSAMC system times are totally unsynchronized. Or you can use a browser to open the certificate file (sslca.crt) and see if the 'Valid From' date-time of the certificate is later than this host system date-time. Adjust the system time to fix it.
239: testarm1: Mar 31 2010 16:33:32.812 +0400: %CSA-4-MC_NOT_REACHABLE: %[Component=Csamanager][PID=1136]: conn_check: Failed to reach mgmtserver csa-mc:443 via HTTPS. Will try again in 12 secs
240: testarm1: Mar 31 2010 16:33:44.812 +0400: %CSA-5-IP_CHECK_OK: %[Component=Csamanager][PID=1136]: conn_check: ip config: ok. one local address is 10.11.0.41
4: testarm1: Mar 31 2010 16:33:44.812 +0400: %CSA-5-FAILED_SEND_FASTPOLL: %[Component=AgentUI][PID=3808]: Failed to send event with code 648
241: testarm1: Mar 31 2010 16:33:44.812 +0400: %CSA-6-MC_DNS_LOOKUP: %[Component=Csamanager][PID=1136]: conn_check: dns : resolved mgmtserver name csa-mc to 10.11.0.2
242: testarm1: Mar 31 2010 16:33:44.812 +0400: %CSA-5-MC_REACHABLE_CHECK: %[Component=Csamanager][PID=1136]: conn_check: https : mgmtserver is not reachable via https
243: testarm1: Mar 31 2010 16:33:44.812 +0400: %CSA-5-CONNCHECK_CMPLT: %[Component=Csamanager][PID=1136]: conn_check: finished
can anyone help, please.?
as i understood, there is a problem with ssl certificate, agents have a root certificate (old server), but old server is unreachable and there is a new server with another root certificate.
