Does CiscoWorks support other devices?
6rlopez_2
I have LMS 3.2 Small Enterprise and I need to manage other devices by SNMP to control basic functions as it is alive ..... Is it possible to do it?
2 Accepted Solutions
Joe Clarke
I assume you mean non-Cisco devices when you say other devices.  Yes, you can get some basic inventory data (mibII) from RME for non-Cisco devices, but that's all.  LMS is really geared toward managing Cisco devices.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Michel Hegeraat
Level 7
Level 7
The DCR supports non-cisco devices.
A customer has those devices in there with the cisco's and added some user defined fields to use it as a central depository for all their devices.
The addon application HUM supports non-cisco devices, and IPM can use these devices as targets.
I will certainly take a  look what RME does. I assumed the inventory and config download would simply fail. So maybe the first one can still do something usefull.
At my customer's LMS, a defined group, holding only the cisco devices, goes to RME and Campus and DFM.
I don't think Campus or DFM will do anything usefull with non cisco devices
Cheers,
Michel
Joe Clarke
Michel Hegeraat
Level 7
Level 7
Cheers,
Michel
