CMT Dialog Group Configuration
Mar 30th, 2010
Hello All,
Does the maximun number of channels have to be limited to the number of licensed IVR ports? What are it limitations by setting it for less or more than the number of licensed IVR ports?
I understand that these channels enable CRS applications to interact with callers while listening and responding to prompts. Do they do anything more?
Matt
Anthony Holloway Wed, 03/31/2010 - 08:37
  • Purple, 4500 points or more
Nope.
None.  Think about service over subscription.  Configuring more or less has its merits, you just need to have a reason.
Nope.  From the documentation:
The Cisco Unified CCX system uses the Media subsystem of the Cisco Unified CCX
Engine to configure Cisco Media Termination (CMT) dialog groups that can be used
to handle simple Dual-Tone Multi-Frequency (DTMF) based dialog interactions with
customers. A dialog group is a pool of dialog channels in which each channel is
used to perform dialog interactions with a caller.
