Callmanager 6.0 Licenses
Answered Question
David Hailey Tue, 03/30/2010 - 09:06
  • Purple, 4500 points or more
CCM Admin > System > Licensing > License Unit Report
Upgrade process depends on what you're trying to do.  If you're trying to upgrade versions and you have current support, you can order your available upgrades thru the Cisco Product Upgrade Tool (PUT).  If you do not have current support OR you need to add additional licensing units (CUWL or DLU), you would want to work with your Cisco AM or Partner to purchase the applicable part numbers to fill your needs.
Hailey
Please rate helpful posts!
Correct Answer
Aaron Harrison Tue, 03/30/2010 - 09:33
  • Community Spotlight Award,
    Member's Choice, May 2015
CCMAdmin
System/Licensing/Licensing Report
Aaron
David Hailey Tue, 03/30/2010 - 09:35
A,
I gave you that info in the previous post.  Look above the paragraph about licensing.  Login into CCM Admin and go from there.
Hailey
