EIGRP msg in the log
Answered Question
Mar 30th, 2010
i'm getting these lines in my switch log and i'm not sure whether to be worried about or what?
034389: Mar 30 02:28:25 central: IP-EIGRP(Default-IP-Routing-Table:100): Neighbor 10.30.13.10 not on common subnet for Vlan306
034390: Mar 30 02:30:46 central: IP-EIGRP(Default-IP-Routing-Table:100): Neighbor 10.30.13.10 not on common subnet for Vlan306
Correct Answer by Jon Marshall about 7 years 2 months ago
Gary
It means that there are 2 EIGRP neigbors on vlan 306 but they have been configured with a different IP/subnet mask. Check the IP address and subnet of every interface on the L3 switches/routers that connect to vlan 306.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Tue, 03/30/2010 - 09:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Gary
Jon
