Aaron Harrison Tue, 03/30/2010 - 09:23
  • Community Spotlight Award,
    Member's Choice, May 2015
Well... it depends.
If you like MGCP, then on the CallManager, as you don't have any choice. This also means any dial plan stuff you have is configured in one place (CCMAdmin) so is theoretically simpler.
If you like ultimate flexibility, then H.323 opens up a lot more options... but is more complex initially (and once you've started getting clever with it).
Aaron
Please rate helpful posts...
Volodymyr Morskyy Wed, 04/07/2010 - 13:40
  • Bronze, 100 points or more
Sometimes you just need to block some calling numbers, it's better to do on ISR.
