Question on testing failover - production
news2010a
Level 3
Level 3
Imagine I setup BGP between 4507 and ISP.
Then once BGP config is in place, I want to take 4507A out of the picture and make sure traffic flows thru the 4507B as per design and I record time it takes to failover to 4507B.
Question:
What is the best way to 'take the 4507A' down in this case? Do you physically power cycle the device or would you just access the 4507A via console port and shut all ports for example? Please let me know your approach.
Jon Marshall
Question:
Marlon
Assuming you are doing this out of core production hours
Best way is to simply shut the port(s) down that connect to the ISP and then you should see it failover to the other 4500.
Edit - reason i suggest shutting down ports rather than rebooting the switch is that you may have clients attached to 4507A that should still be able to get out via the interconnect to 4507B.
Jon
Jon Marshall
Question:
Marlon
Jon
news2010a
Level 3
Level 3
Definitely during maintenance window. Thanks.
