03-30-2010 09:23 AM - edited 03-04-2019 07:58 AM
All,
Any recommendations for an inexpensive way to convert a single Mode Fiber handoff to 100Mbps Ethernet? We have a customer that needs to do a temporary solution before they purchase a Cisco HWIC and Fiber SFP. I've done a search and found many but wanted to see if anyone has some real experience on which ones work better and which ones to stay away from.
Thanks in advance. All replies rated!
Solved! Go to Solution.
03-30-2010 11:37 AM
I'm using a converter by Telco System (2141) and it works pretty good.
03-30-2010 09:33 AM
Any converter should work. Note they are not much cheaper than cisco parts.
03-30-2010 09:45 AM
Thanks. I hope I am on the right trail. I am seeing converters for around $100 versus
the HWIC for the 2800 router going for $1000 and the Fiber SFP going for about $600.
Am I not looking at the correct hardware?
Please see the link below.
http://www.cablesandkits.com/tplink-gigabit-singlemode-fiber-converter-1310nm-15km-p-1717.html
03-30-2010 10:27 AM
Cannot comment on these prices, but there is alwas a "better" way to buy.
03-30-2010 11:37 AM
