Jon Marshall Tue, 03/30/2010 - 11:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
b.rockburn wrote:
How do I upgrade the licensing level on a router?
Brent
Could you clarify. Do you mean upgrade feature set or are you referring to the new 15.0 IOS with different license files ?
Jon
Brent Rockburn Tue, 03/30/2010 - 12:11
I have an
881 and when I try to configure eigrp it gives me an error saying that this image doesn't support that protocol.
So I need to upgrade the license level from advsecurity to advipservices.
Jon Marshall Tue, 03/30/2010 - 12:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
b.rockburn wrote:
I have an
Brent
If it is pre 15.0 IOS version then you don't use a license, you simply download the advanced IP service image from Cisco, although there may well be a charge.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
