Cisco Unified Mobility Advantage Software Eval?
Mar 30th, 2010
I want to test out the Cisco Unified Mobility Advantage (CUMA) software for testing purposes to use with the Cisco Mobile app on the iPhone.
Apprently a CUMA server is required in order to use the Cisco Mobile app on a iPhone.  Unless someone else says differently.
Is there a place where engineers can down a demo/eval this software?
Thank you!
Overall Rating: 5 (3 ratings)
David Hailey Tue, 03/30/2010 - 12:47
You are correct the Cisco Mobile app for iPhone requires CUMA for operation.  This is the equivalent of the UMC client for Blackberry which also requires CUMA.  Unfortunately, I don't believe (but have not confirmed) that CUMA comes with a demo license.  In addition, truly testing the application would require other hardware (ASA for proxy functionality) as this goes along with the CUMA architecture.  Your best bet is to likely discuss an evaluation with your Cisco AM.
Please rate helpful posts!
htluo Tue, 03/30/2010 - 13:29
In addition to David's excellent post, Cisco is chaning the mobility strategy.
CUMA server will be phased out in the future while more features being built into CUCM and CSF-based mobile clients (CUMC).
Related Content
