How to log Success and Failed Login Attempt Details to Router into Syslog?
jaesposito
All,
How can I configure my Cisco 837 router to log to syslog all successful and failed login attempts to the router via any interface?  I'd like to get as much verbose information about the login attempts (success and failed) as possible including source ip address, userid attempted, etc.
Any comments and suggestions would be greatly appreciated!
James
archive
log config
  logging enable
  notify syslog contenttype plaintext
  hidekeys
logging on
logging 192.168.1.1
login block-for 60 attempts 3 within 60
login on-failure log every 1
login on-success log every 1
10 Replies 10
Collin Clark
You will need to send logging to a syslog server with a level of informational.
Here's a link on configuring message logging. It's for a switch, but it should be the same for routers.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swlog.html
Hope it helps.
I'm receiving an error when trying to visit that link.  Can you copy/paste the instructions into your response?  Thanks!
James E
Sorry about that James, I didn't realize I was logged into CCO. Please try this link-
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_50_se/configuration/guide/swlog.html
jaesposito
Any other specific links to routers?  I'd like little to squeeze as much information out of syslog as possible for successful and failed login attempts.
Thanks!
James
archive
log config
  logging enable
  hidekeys
logging on
logging 192.168.1.1
Also take a look at SNMP Authentication traps.
RTR(config)#snmp-server trap authentication ...
Is it possible to filter only syslog information relative to the list of this events:
User Authentication
IKE and IPSec
VPN Client
VPN Failover
If yes what will be the best process
@joearmstg @jaesposito, I had this same problem just yesterday.  Please rate the potential solution below if helpful.
This is an answer to the question using automation.  See also, my other answer to perform Regex matches manually to filter syslog messages.
! Turn on terminal monitoring to display syslog messages to the terminal
term mon
! Turn on system archive logging.
archive
 log config
  record rc
  logging enable
  hidekeys
! Create an EEM applet to capture config changes and login/logouts to file.
event manager applet <YOUR-EEM-APPLET-NAME>
! Match the criteria you would like in your syslog messages
 event syslog occurs 1 pattern "<YOUR-SYSLOG-MESSAGES>"
! You may want to use ("LOGIN|LOGOUT|PARSER-5-CFGLOG_LOGGEDCMD") but see the NOTE(s) below first.
! Open the Logger file in append mode.
 action 1.0 file open fh <YOUR-FILE-NAME> a
! Write the syslog pattern matches to your file.
 action 1.1 file write fh "$_syslog_msg"
 action 1.2 file close fh
! Exit config mode and view the syslog messages matched to your file name.
more <YOUR-FILE-NAME>
! NOTE WARNING: These changes have not been attempted and validated by anyone.  If you choose to test them yourself, do so at your own risk.
! NOTE WARNING: You should check your system for proper storage space and take precautions so that your local storage does not exceed levels as you deem appropriate for your environment.  Also, the matching criteria you used in the "event syslog occurs 1 pattern" section can inadvertently fill up your storage system if you make the criteria too broad, or if the criteria match a condition that occurs frequently.  Do so at your own risk.
Maybe someone would still like an answer to this old question.  You can use regular expression (Regex) pattern matching.
For instance you can run the following command to include/exclude/count/begin/section any messages with a keyword in them:
INCLUDE:
show log | include CRYPTO
show log | i OSPF
show int status | i notconnect
INCLUDE MULTIPLE:
Combine multiple options using a pipe "|" symbol to separate them:
show log | i CRYPTO|OSPF|BGP|LOGIN|LOGOUT
EXCLUDE:
show log | exclude ADJCHG
show ip int br | ex una
show int status | e notconnect
START OF LINE:
to show a route that begins with a pattern, begin with the caret symbol (^) which means "beginning of line":
show ip route | i ^O
show ip route | i ^O|^S
show ip route | i ^O|^B|^S
COUNT:
or count a matching criteria - this will count the number of static routes in your route table:
show ip route | count ^S
SECTION:
to see all the indented lines following a matched criteria such as bgp, route-maps, or line commands
show run | section route-map
show run | sec bgp
show run | sec line
BEGIN:
the begin operator works well if the section of configuration is not indented, or you're just looking to start at a general area within your config, or syslog output
show run | begin interface
show run | b banner
show log | b May 16
Regular expression (REGEX) is also useful for matching criteria in route-maps.  There are good articles on the internet explaining Regex special characters.  Here are a few of the basics.
. = any character
* = any number of times
.* = any character any number of times (basically means anything)
| = or
[0-9] = any single digit matching the numbers 0 through 9.
for instance show log | i Vlan[9][0-9][0-9] matches Vlan900 through 999 in your syslog messages
[a-z,A-Z] = any letter upper or lower case
^ = beginning of line
$ = end of line
^$ = an empty line a.k.a. carriage return (a line that starts and ends without any other characters on that line)
_ = a space
\ = escape (removes special meaning from special characters, or applies special meaning to standard characters)
for instance \$ means match the dollar sign instead of the end-of-line
https://www.cisco.com/c/en/us/td/docs/ios/12_2/dial/configuration/guide/dafaapre.html Cisco Doc on Regex
https://www.rexegg.com/regex-quickstart.html Regex Cheat Sheet
https://packetlife.net/blog/2008/may/10/extracting-bgp-info-regex/ Packet Life BGP Regex Cheat Sheet
https://regexlib.com Regex Library and Test pattern matching tools
zjnbxsspjm
Are there any similar commands on Nexus? i want to log all attempts to establish a management connection for administrative access to nexus.Thanks
