CCM 7.x and VG224 Device Setup
Mar 30th, 2010
When configuring a device on a CCM 7.x and VG224, do you have telnet to to the VG as you wold in a VG248 or it it all done through the admin portion of the CCM via Device > Gateway?
I have built a user and when plugged in, their is dial tone, but noting happens when dialing from that port.
Am I missing something?
Aaron Harrison Tue, 03/30/2010 - 15:02
Yes, it's an IOS gateway.
You configure it like you would an ISR - go in and do the SCCP or MGCP config from the box in conjunction with the CCM side stuff.
Aaron
Please rate helpful posts...
arthurbecker Tue, 03/30/2010 - 15:32
The devise is already setup, it is adding users/ports that is the issue.
David Hailey Tue, 03/30/2010 - 15:53
If you're doing SCCP (keyword in IOS is "stcapp"), you configure the stations as SCCP devices similar to phones.
If you're doing MGCP on the gateway, you configure the ports within the gateway configuration page on a port-by-port basis.
Hailey
Please rate helpful posts!
