cdp neigh btwn N5k
Mar 30th, 2010
Why doesn't cdp neigh show both ports like 1/1 and 1/2 of the port-channel other than mgmt0? I have the same cdp output on the other N5k
N5K-EDGE2-DC(SSI13500AD5)mgmt0         145    S I s     N5K-C5010P-BF mgmt0
N5K-EDGE2-DC(SSI13500AD5)Eth1/2        152    S I s     N5K-C5010P-BF Eth1/2
interface port-channel200
  description ****TO-N5K-EDGE2-DC PORTS 1 and 2****
  switchport mode trunk
  vpc peer-link
  spanning-tree port type network
  logging event port link-status
  logging event port trunk-status
interface Ethernet1/1
  untagged cos 0
  channel-group 200 mode active
interface Ethernet1/2
  untagged cos 0
N5k-Edge1-DC# sh int por 200
port-channel200 is up
  Hardware: Port-Channel, address: 000d.ecf6.8e09 (bia 000d.ecf6.8e09)
  Description: ****TO-N5K-EDGE2-DC PORTS 1 and 2****
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  Members in this channel: Eth1/1, Eth1/2
Ganesh Hariharan Thu, 04/01/2010 - 11:12
Genarally by default CDP is enabled in interfaces what is the output shows in second switch it shows all the interfaces or same type what it shows in switch1.
Ganesh.H
