SPA9000 to SPA9000
Mar 30th, 2010
I am trying to setup two offices that have a VPN connection to each other - each office has a SPA9000 and SPA400 combo.  I would like to be able to dial extensions between the sites, but am unable to locate any doc on how to setup a site to site sip trunk ( I think I can figure out the dial plan if I can get the two 9000s to register).  Can someone point me in the right direction?
nseto Thu, 04/01/2010 - 14:29
  • Silver, 250 points or more
Since you'll be using a VPN, you can have all the phones connected to one spa9000.  One spa9000 supports up to 16 phones.  Connect a spa9000 to another spa9000 isn't supported.
Kenneth Lee Thu, 04/01/2010 - 15:01
Thanks for the reply.  I am slightly confused though.  There is another thread  (https://www.myciscocommunity.com/thread/11177?tstart=0) where it is referenced that  "You can have 3 SPA9000, but not behaving as a single unit. You would need to connect 1 SIP trunk to each of the neighbors (i.e. two SIP trunks).".  How do I go about making this happen?
nseto Thu, 04/01/2010 - 15:18
From the description at that link, it sounds like you would obtain a SIP trunk from an internet phone service provider for each spa9000.  So you can then call the other spa9000 after you have that new SIP trunk number.
Kenneth Lee Sat, 04/03/2010 - 16:35
Ok....well....  I guess I will have to find another solution for my local lines in one office then.  I'll use your sugguestion until I can figure that out.
As multicast does not come across the VPN tunnel, how do I go about adding the SPA962 to a SPA9000 adaptor on the other side of the tunnel?
Alberto Montilla Sun, 04/04/2010 - 06:21
  • Cisco Employee,
Hi Kenneth;
You would require either manual configuration or connecting/configuring the phones in office 1 before installing them in office 2.
Alberto
Related Content
