ā03-30-2010 08:03 PM - edited ā03-21-2019 02:23 AM
'm attempting to factory reset a UC560 and running into all kinds of issues...I've tried the below steps on both a Win7 Laptop and WinXP VM (firewall off and other NICs disabled) all running CCA 2.1 (2).
From the Maintenance -> Restart/Reset menu, I've managed to get 3 different errors over the many times I've tried this:
1. "Reset Error: Default vlan copy failed. Accessing tftp://10.10.2.54/2539926491127... %Error opening tftp://10.10.2.54/2539926491127 (Timed Out) "
**Usually get this immediately after rebooting the UC560 (10.10.2.54 is my laptop)
2. "Voicemail Communication Failure: System detected voice mail not be in an Operational State. If you are doing a Voicemail Compact Flash Upgrade, click Yes to perform upgrade; click No to Continue Normally".
**I have clicked yes and sucessfully ran an upgrade using UC560-8.0.2.zip
3. "Reset Error: CUE Reset failed."
**Usually get this on subsequent attempts, tried to run all kinds of CLI reset commands to resolve.
I've tried to run a Software Upgrade from the UC560-8.0.2.zip, but get "Cannot retrieve CUE version information"
I finally found the CLI commands to run it below, should these work on my UC560? I tried pulling out the CF and copying UC560-FXO-K9-factory-8.0.2 over a card reader, but it didn't work...
https://cisco-marketing.hosted.jivesoftware.com/message/35599
Two Steps:
1) CUE: Session to the CUE and restore factory defaults. If you never configured voice mail before, this may not be required, but if you did, you must do this or old data will not be cleaned up and will cause weird behavior from AA trying to reach users by names and when trying to log into a phones voice mail box, you will not have the correct user ID and PW. This will give you a clean system. no users and no voicemail
UC520# service-module integrated-Service-Engine 0/0 session
This will take your into CUE system where you can issue the following commands:
UC500-CUE> offline
!!!WARNING!!!: If you are going offline to do a backup, it is recommended that you save the current running configuration using the 'write' command, prior to going to the offline state.
Putting the system offline will terminate all end user sessions.
Are you sure you want to go offline[n]? : y
UC500-CUE(offline)> restore factory default
!!!WARNING!!!: This operation will cause all configuration and data
on the system to be erased. This operation is not reversible.
Do you wish to continue[n]? : y
Restoring the system. Please wait .....done
System will be restored to factory default when it reloads.
Press any key to reload: <enter>
2) CME: copy the default configuration file to the startup-config and then reload the router.
copy flash:UC520W-16U-4FXO-K9-factory-15.0.1.cfg startup-config <--this is specific to your model of course
reload
Anyone know a surefire way to factory reset this thing!?!
ā03-31-2010 05:27 AM
I wish you would have waited for the answer. Would have saved you alot of time.
UC560 wasnt supported until CCA 2.2.
Your on 2.1. As the Robot on Lost in Space would say..."it does not compute"
Please download CCA 2.2.2. Its got alot in there..... www.cisco.com/go/configassist
Steve
ā03-31-2010 05:39 AM
Yes, the CLI commands you have listed will factory reset your UC560... What I would suggest, is to follow the commands:
1) CUE:
UC520#service-module integrated-Service-Engine 0/0 session
UC520-CUE>offline
UC520-CUE(offline)>restore factory default
System will be restored to factory default when it reloads. (5-10 minutes)
UC520-CUE>exit <--Exit CUE
UC520#show flash <--- Factory config file should be listed close to the bottom.
UC520#copy flash:UC520W-16U-4FXO-K9-factory-8.0.0.cfg startup-config <--this is specific to your model of course.
UC520#reload (5-10 minutes)
Once this has completed, open CCA, cancel the setup wizard, run the upgrade again.
Or like Steve said, download CCA 2.2.2
Thank you,
Darren
ā03-31-2010 01:32 PM
I doubled checked and unfortunately for me I am already running CCA 2.2 (2), not sure where I got 2.1 from in my post...
I've tried to go through the CLI reset again and keep getting stuck at the copy command, tried both flash and tftp. What am I missing?
se-10-1-10-1# copy flash:UC560-FXO-K9-factory-8.0.2.cfg startup-config
% Invalid input detected at '^' marker.
se-10-1-10-1# copy tftp://10.10.2.4/UC560-FX0-K9-factory-8.0.2.cfg startup-config
My full session output is attached...
ā03-31-2010 01:35 PM
In your snapshot, you are entering IOS commands in the CUE prompt.
We built CCA to make this easy for you and it will work.
Please open a case with SBSC and they will help you and if there is a problem, they will isolate it.
ā03-31-2010 01:59 PM
ahh, thx I see that now. I entered the commands into IOS and everything looked to work, but IP hasn't changed and I can still login with my credentials!!!
Calling support....
ā02-18-2011 08:08 PM
Did you get any help with this?
I am running CCA 3.0 - and if you run into problems, then a factory reset is just near impossible to achieve.
Problem with support is, it is inundated with calls - so if you are running a business, sitting on a phone for hours waiting to get a call back is not the best solution.
Why is this so hard?
