3825,System returned to ROM by bus error HELP!!!!
Mar 30th, 2010
hi all
i have 3825 router ,the devie restarts once every other day
please find the error showing in "Show version"
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(24)T2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 19-Oct-09 21:06 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
yongwang-sz-sfgc uptime is 3 minutes
System returned to ROM by bus error at PC 0x601068F8, address 0xB0D0AF9 at 10:22:59 UTC Mon Mar 29 2010
System image file is "flash:c3825-advipservicesk9-mz.124-24.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3825 (revision 1.2) with 224256K/37888K bytes of memory.
Processor board ID FTX1012A4BJ
2 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
63488K bytes of ATA System CompactFlash (Read/Write)
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x0FFFFE00  0x0FFFFFFF         512  Iomem  R/W    BCM region
0x2DB00000  0x2FFFFDFF    38796800  Iomem  R/W    iomem
0x60000000  0x6DAFFFFF   229638144  Local  R/W    main
0x600135C0  0x641BA253    68840596  IText  R/O    main:text
0x641BECC0  0x670DFFDF    49419040  IData  R/W    main:data
0x670DFFE0  0x67BB655F    11363712  IBss   R/W    main:bss
0x67BB6560  0x6DAFFFFF    99916448  Local  R/W    main:heap
0x80000000  0x8DAFFFFF   229638144  Local  R/W    main:(main_k0)
0xA0000000  0xADAFFFFF   229638144  Local  R/W    main:(main_k1)
Ronit Bhattacharjee Wed, 03/31/2010 - 06:46
The router must have spawned a crashinfo file when it rebooted. If you can get me that, I can try looking for known bugs and un-affected IOS versions
Related Content
