ESW 520 24 Switch Setup Help
I am a newb at these managed switches. I have read the 442 pages that explains things a couple of times but i am having a little hard time getting my switch setup in its simples form. I will have two A/P one to the whole network while the other will be for guests to get them on the internet. Trying to set the guest side up is where I am having the problems. The Instructions say to pick "guest" as the Assign Profile but guest does not appear anywhere I can find it...
The Software Version is 2.0.3
Boot Version is 1.0.0.04
I need to be pointed in the right direction, just do not know where that is at the moment...
JORGE RODRIGUEZ Wed, 04/07/2010 - 09:04
  • Green, 3000 points or more
Hi  Chris ,  did you follow instructions based on this pdf  page 87
Administration guide attached pdf
try posting  your question on small business switches support forum - much bigger audience  pertaining this switch.
https://www.myciscocommunity.com/community/smallbizsupport/switches?view=overview
Related Content
