03-30-2010 10:10 PM - edited 03-15-2019 10:03 PM
This seesms to be a common problem for users installing the PWR-2811-AC-IP to provide inline power to the HWIC-4ESW-POE, but I can't seem to find a solution to my own situation. I have both of these installed in a 2811 and I can't not get inline power to my phones. I would be grateful if someone could help. After installing the power unit, do I need to run a command for inline power to work? I noticed that the PWR-2811-AC-IP is identical in appearance to the power unit I replaced it with. Are there any other connections besides the one to the motherboard that need to be done?
P1-BR2-VG#show diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:20:41 ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC11524YD6
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-04
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20071227
Chassis Serial Number : FTX1203A3AE
Chassis MAC Address : 001e.7a5e.e7d8
MAC Address block size : 24
CLEI Code : COM7R00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V05
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 31 35 32 34 59 44 36 40
0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 43 3B C2 8B 46 54 58 31 32 30 33
0x40: 41 33 41 45 C3 06 00 1E 7A 5E E7 D8 43 00 18 C6
0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8538-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC12021YR0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-16
Version Identifier : V01
0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 42 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 30 32
0x20: 31 59 52 30 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 3.2
Part Number : 73-8539-04
Board Revision : A0
Fab Version : 03
PCB Serial Number : FOC09373S77
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-32
Version Identifier : NA
0x00: 04 FF 40 03 EE 41 03 02 82 49 21 5B 04 42 41 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 30 39 33 37
0x20: 33 53 37 37 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 33 32 89 4E 41 20 20 D9 02
WIC Slot 0:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : C0
Fab Version : 04
PCB Serial Number : FOC130720NQ
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 33 30 37 32 30 4E 51 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
WIC Slot 1:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC11520URW
Part Number : 73-8346-05
Board Revision : A0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 31 35
0x10: 32 30 55 52 57 82 49 20 9A 05 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
0x30: 2D 31 44 53 55 2D 54 31 2D 56 32 20 20 20 20 20
0x40: 20 C0 46 03 20 00 56 B1 03 C6 8A 49 50 55 49 41
0x50: 50 52 52 41 41 FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 2:
4 Port FE Switch
Base MAC Address : 0019.2fe6.b1ce
MAC Address block size : 4
PCB Serial Number : FOC103531CQ
Hardware Revision : 5.1
Part Number : 73-8474-05
Board Revision : B0
Top Assy. Part Number : 800-24193-01
Fab Version : 05
CLEI Code : IPUIAE0RAA
RMA History : 00
Product (FRU) Number : HWIC-4ESW
Version Identifier : VN/A
Connector Type : 01
0x00: 04 FF CF 06 00 19 2F E6 B1 CE 43 00 04 C1 8B 46
0x10: 4F 43 31 30 33 35 33 31 43 51 40 00 56 41 05 01
0x20: 82 49 21 1A 05 42 42 30 C0 46 03 20 00 5E 81 01
0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 45 30
0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
0x50: 49 43 2D 34 45 53 57 89 56 4E 2F 41 D9 02 C1 40
0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
4-Port HWIC-ESW Power Daughter Card:
Hardware Revision : 3.0
Part Number : 73-8476-03
Board Revision : A0
Fab Version : 03
PCB Serial Number : FOC10353NXA
RMA History : 00
Product (FRU) Number : ILPM-4
CLEI Code : IPUPAAKAAA
0x00: 04 FF 40 00 57 41 03 00 82 49 21 1C 03 42 41 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 30 33 35
0x20: 33 4E 58 41 03 00 81 00 00 00 00 04 00 CB 86 49
0x30: 4C 50 4D 2D 34 89 56 4E 2F 41 C6 8A 49 50 55 50
0x40: 41 41 4B 41 41 41 FF FF FF FF FF FF FF FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF 9F C8
AIM Module in slot: 0
Service Engine AIM: 0
Top Assy. Part Number : 800-20063-06
Board Revision : B0
Deviation Number : 93519
Fab Version : 05
PCB Serial Number : FOC11525S7B
RMA History : 00
Product (FRU) Number : AIM-CUE
Version Identifier : V03
0x00: 04 FF 40 03 8E 41 01 00 C0 46 03 20 00 4E 5F 06
0x10: 42 42 30 88 00 01 6D 4F 02 05 C1 8B 46 4F 43 31
0x20: 31 35 32 35 53 37 42 03 00 81 00 00 00 00 04 00
0x30: CB 87 41 49 4D 2D 43 55 45 89 56 30 33 20 FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
P1-BR2-VG#show envi
Main Power Supply is AC
Fan 1 OK
Fan 2 OK
Fan 3 OK
Fan Speed : Normal
System Temperature: 28 Celsius (normal)
Environmental information last updated 00:00:14 ago
P1-BR2-VG#show version
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 00:06 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
P1-BR2-VG uptime is 21 minutes
System image file is "flash:c2800nm-ipvoicek9-mz.124-22.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FTX1203A3AE
6 FastEthernet interfaces
5 Serial interfaces
1 terminal line
2 Channelized/Clear E1/PRI ports
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
1982232K bytes of ATA CompactFlash (Read/Write)
P1-BR2-VG#
Solved! Go to Solution.
03-31-2010 03:31 AM
See this page:
http://www.cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/10_hw.html#wp1161133
The Inline Power PSU should have a secondary connector in it which you need to cable in as indicated.
Maybe if you don't do that, it doesn't get identified...
If you don't have the secondary connectory, I guess you have the incorrect part.
Aaron
Please rate helpful posts...
03-31-2010 01:36 AM
You do not have PWR-2811-AC-IP, but just a regulat PS AC. Show env is telling you that also.
03-31-2010 03:21 AM
P, what should the "show inv" show if the power unit were correct? This power unit came in a Cisco box sealed at the factory, hard to believe it's not the right one, but I can't fund any model number on it. The power unit that was pulled from the router doesn't have one either.
03-31-2010 03:31 AM
See this page:
Aaron
03-31-2010 05:52 AM
Yup, that's the problem. Thanks, Aaron.
03-31-2010 06:27 AM
No problem.
05-12-2012 07:59 AM
Hey Guys,
I know this thread is old but I am having the same issue and it appears that I am missing the ILP Connector as well, how can I go about getting a couple of these cables?
03-31-2015 07:38 AM
Thank youuuuu!!!
