bgp suppress-inactive !
Mar 31st, 2010
Hi all,
I was doing my studies on bgp and came around this line in configuration guide
the bgp suppress-inactive command was introduced to configure BGP to not advertise inactive routes to any BGP peer. A BGP routing process
can advertise routes that are not installed in the routing information database (RIB) to BGP peers by default. A route that is not installed into the RIB is an inactive route.
When i tried it creating a rib-failure condition, it was still advertising it, when i searched at google, the reason was something related to next hop mismatch. My confusion is, why this condition is not specified in any cisco doc anywhere ? Is it referred in any RFC ?
Edison Ortiz Wed, 03/31/2010 - 11:55
  • Hall of Fame,
    Founding Member
Hi Jonn,
The issue is that RIB failure in BGP can also occur if the route is installed on the RIB under another routing protocol with better AD.
This is not considered an inactive route and the command will not function as advertised.
You have to force the route to be inactive by making sure is not on the RIB
You can verify if the route is on the RIB or not by typing 'show ip route'.
Edison
______
Each time you rate a CSC   discussion   we'll donate $1 to the American Red Cross Haiti fund up to a   maximum   donation of $10,000 USD.
https://supportforums.cisco.com/docs/DOC-8895
Jonn cos Sun, 04/04/2010 - 22:46
Dear Edison, sorry i couldnt reply in time. I hope you dont mind.
I was searching for my post and came around this one
https://supportforums.cisco.com/message/818712#818712
In this post you said, inactive routes are those that are shown with r> tag. But over here you are saying
"The issue is that RIB failure in BGP can also occur if the route is installed on the RIB under another routing protocol with better AD.
This is not considered an inactive route and the command will not function as advertised."
I am just confused as to what i am missing.
Thanks in advance
