VPN between ASA and Juniper?
Jon Marshall Wed, 03/31/2010 - 02:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
[email protected]
Hello
can we terminate Site-to-site VPN between ASA and Juniper?
Ali
Yes you should be able to do that as long as the Juniper supports IPSEC. Have a look at this link -
Pix to Netscreen site-to-site VPN
Note that Netscreen firewalls are now owned by Juniper. The pix config is for 6.3 but it can easily be modified to 7.x code for the ASA. The above link is just to show that you can create site-to-site VPNs between different vendors firewalls.
Jon
