how to configure 3 VWIC2-1 MFT E1 card
eahmed007
Dear All,
              I having problem to configure E1 card (VWIC2-1 MFT E1 ) to get aggregate Bandwidth.can anybody tell that how to configure 3 E1 card in a router to get 6 Mbps bandwidth as one E1 support 2 Mbps bandwidth.Please need you assistance on this issue.I am not able to finish the project with this configuration.
I am keenly waiting for your valuable help.
Thanks and regards..
Erfan
5 Replies 5
kumarmanish26
Hi Erfan
You have an option of creating a MLPPP bundle on the router and you can use 3E1 for that
thxz...
Manish
Hi Manish,
               Thanks for your prompt support.Can you tell me any documents for this configuration.
I am keenly waiting for your reply.
Thanks and regards...
Erfan
pls find the attached doc may be it will help you.
brgds...
Manish
This is a simple config. Just remove all layer 3 config from the serial interfaces and do this
interface multilink 1
encap ppp
ppp mul
ppp mul group 1
int serial 1/0:0
encap ppp
ppp mul
ppp mul group 1
int serial 1/1:0
encap ppp
ppp mul
ppp mul group 1
int serial 2/0:0
encap ppp
ppp mul
ppp mul group 1
Configure all the serial interfaces identically and have the Layer 3 config on the multilink interface. Do the same on the other end.
Hi Ronit,
             Thanks for your reply and help.I will configure  accordingly.I will let you know if i face any problem.
Erfan
