SSL
Answered Question
Mar 31st, 2010
Hello Netpro
I need to publish a website on a DMZ Server with Active Directory authentication. Its not a public website.
I need to understand the advantages/disadvantages of publishing with SSL and without SSL
thanks
Nasr
Correct Answer by Aaron Harrison about 7 years 2 months ago
Well - what's important is how the AD credentials are sent from client to server.
SSL will ensure that the credentials are encrypted even if the credentials are set to 'plain text' in IIS...
It will also validate that the server users are connecting to is the server it says it is - really anywhere where you want users to put their AD credentials (which if compromised could get someone access to any number of things) should be verified in this way...
Aaron
Please rate helpful posts..
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Wed, 03/31/2010 - 04:06
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
