Probleme With FXO Card
Mar 31st, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Hi All,
I have a problem on  FXO card. And I think that it is problem of configuration
I call numbers of line connected in FXO card, and I take down the call before the IP Phone answers me, the IP Phone continues sounded without stop, (approximately 120s)
Here configuration of chart FXO:
voice-port 0/1/1
no battery-reversal
output attenuation -6
cptone FR
timeouts interdigit 2
timeouts call-disconnect 0
timeouts wait-release 1
connection plar 130
impedance complex2
Thank you for your Help
Overall Rating: 5 (1 ratings)
Aaron Harrison Wed, 03/31/2010 - 09:20
  • Community Spotlight Award,
    Member's Choice, May 2015
OK, so I've not done this in your country...
Your best option is to go through some trial and error using some of the options in that document I posted. Apply one config, then shut/no shut the port and test it again.
Aaron
paolo bevilacqua Wed, 03/31/2010 - 11:58
  • Hall of Fame,
    Founding Member
To begin with, use "connection plar opx".
