how do you backup controller config
Mar 31st, 2010
Does anyone know how to backup your controller config? I have templates saved my my WCS. Would sending the template out be the same thing as as restoring a backup of the config?
dancampb Wed, 03/31/2010 - 07:24
  • Cisco Employee,
You can either go under the scheduled tasks in WCS and setup automatic backups or you could go onto the controller under Commands - Upload Files and upload the config off of the controller to a TFTP server.
starthorn2 Wed, 03/31/2010 - 07:49
in WCS Administration                 >  Background tasks>                 Other Background Tasks                 >             Controller Configuration Backup
It looks like it has been backing them up. Where can I find the config files it has backed up?
sschmidt Wed, 03/31/2010 - 07:59
  • Cisco Employee,
Usually it will be in the default FTP directory for WCS.
If it is 6.x you can check here for that directory:
Administration > Settings > Server Settings
starthorn2 Wed, 03/31/2010 - 09:27
I located the config files. It is only 16 KB. Does that sound right?
sschmidt Wed, 03/31/2010 - 09:35
  • Cisco Employee,
It was in the tftp directory wasn't it?  I think I mistyped.
Mine are about 80k but I guess they could be that small.
starthorn2 Wed, 03/31/2010 - 11:39
yeah tftp. Doesnt tell you the IP of the server is though. I guessed it was on the WCS windows server
