Tomas De Leon Mon, 04/05/2010 - 07:18
b.lang,
In the DMM-DSM Cast Setup Configuration, You can configure a under
the remote contol a URL that you can use for controlling the CAST
screens.
The only issue (which is known) is the length of the URL.  It is NOT long
so you may have to use a "TINYURL" (if you have access to the internet)
or use DNS to shorten the URL length:
Ie.
dmm-fqdn:8080/m
When this is configured; PCs, iPhones, iTouches, or Smart Devices can
control the CAST displays.
Cheers!
T.
b.lang Mon, 04/19/2010 - 08:35
Hi Tomas,
thanks for your post!  It works fine.
Within Cast/Remote-control I can setup the PINs for the Emulatet Remote Control of each DMP!
Does anybody know if this PINs are also usable with the real Remote Control?
Bernhard
Tomas De Leon Tue, 04/20/2010 - 11:04
Bernhard,
The Pins will not work with regular remotes.
What you can use is iTouches & iPhones or any
smart device which can access the IP network and
got to the URL to enter the pin.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
