Limited location feature
Answered Question
I have one WLC 5508, 10 1140APs and demo WCS (PLUS license). As is mentioned here: http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/product_data_sheet0900aecd804b4646.html
Cisco WCS PLUS includes all WCS Base  features plus the ability to track location of a  single Wi-Fi device such as a client, tag, or rogue access point on  demand (limited location).
Could someone give me some info, how this feature works? Or what to setup, to get it work? Im trying it couple of days with no success and also Im not able to find any info or documentation.....
Thanks for reply
Correct Answer by b.ericson about 6 years 9 months ago
ok now to the rouge ap:
monitor/alarms:
click on the rouge ap you want to locate and do the same as you did with the client:
select "map (high resolution)" on the drop-down menu.
/bjorn
to see one of your clients:
monitor/client/pick the user you want to see.
From here you choose "recent map ....)" from the drop down menu up in the right corner.
done!
/Bjorn
Overall Rating: 5 (2 ratings)
sschmidt Wed, 03/31/2010 - 07:57
How are you trying to view the client?  If you go to Monitor > Clients > Click on an associated client down in the right corner do you see the box that says Map?  Can you click there to view the client?
What (with map) can I only see on this tab is: "AP Map Location". When I click the link for the map under, I can see APs and coverage levels, but no client location.....
Screenshot of the client info and Edit setings is attached.
Regards Jiri
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normální tabulka"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} Re: Limited location feature
Correct Answer
b.ericson Thu, 04/01/2010 - 02:27
done!
/Bjorn
Correct Answer
b.ericson Thu, 04/01/2010 - 04:14
monitor/alarms:
/bjorn
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
