Load balance on 3750 over 2 ISP
Answered Question
Mar 31st, 2010
I got 2 sites, both with 3750 installed and they are connected using 2 ISP. I found the command "ip load-sharing per-packet" is not supported on 3750. How can I distribute traffic evenly over the 2 links?
Correct Answer by paolo bevilacqua about 7 years 1 month ago
Per-flow balancing, that is the optimal method.
Per-packet introduces out-of-order arrival and must be avoided.
Please remember to rate useful posts clicking on the stars below.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 03/31/2010 - 07:50
  • Hall of Fame,
    Founding Member
You cannot, beside a 3750 is not apt for connecting to ISP.
y.lo Wed, 03/31/2010 - 07:59
So there is nothing we can do to make the situation better? Would disabling route cache help a bit?
Also, there seems to be a table that stores the destination address of traffic. Would this table has a timeout value? Thanks.
paolo bevilacqua Wed, 03/31/2010 - 08:28
  • Hall of Fame,
    Founding Member
You have a L3 switch, there is no route cache and stuff like that.
The device is already operating at its best, if you want more options, get a true router.
y.lo Wed, 03/31/2010 - 08:34
Thanks for your reply. What if there are 2 or more optimal routes to the same destination network? How would it forward the packet?
Correct Answer
paolo bevilacqua Wed, 03/31/2010 - 08:41
  • Hall of Fame,
    Founding Member
