cochrancw Wed, 03/31/2010 - 11:39
These instructions do not work with the 9124, I had already tried this.  When you reboot the 9124 and insert a break command the menu options are not the same as the large director level switches.  Any other instruction would be much appreciated.
Filiph Westman Wed, 04/21/2010 - 00:05
I have done it several times on the 9124 and it's the same procedure.
You need to get to the switch(boot)# prompt to reset password. Press ctrl+] exactly when you see "Loading system software". The message "Switching to runlevel: 1" indicates you are entering switch(boot)# prompt.
=== console output ===
Starting kernel...
INIT: version 2.78 booting Checking all filesystems..... done.
*** BREAK SIGNAL SENT ***
INIT: Switching to runlevel: 1
INIT: Stopping kernel log daemon: klogd.
Sending all processes the TERM signal... done.
Sending all processes the KILL signal... done.
Entering single-user mode...
INIT: Going single user
INIT: Sending processes the TERM signal Cisco Storage Area Networking Operating System (SAN-OS) Software
/// snippet ///
switch(boot)#
switch(boot)# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
switch(boot)(config)# ?
Configure commands::
  admin-password  Set password for admin
  do              EXEC command
  end             Exit from configure mode
  exit            Exit from configure mode
  hostname        This system's network name
  interface       Select an interface to configure
  ip              Configure the ip parameters
  no              Negate a command or set its defaults
switch(boot)(config)# admin-password whatever12345
PAM_unix[597]: Password for admin was changed
=== end ===
Rgds Filiph
orrobinson Fri, 08/20/2010 - 02:09
Can you please tell me if the switch configuration is lost after you do the password recovery?
Oliver
Gary Ross Thu, 08/26/2010 - 20:38
Oliver,
No, you will not lose you switch configuration.  You're performing a "conversational boot".  Basically, you're walking the switch through what images to load.  Once the load is complete of the kickstart and system images, you remain logged in with network-admin rights which allows you to reset your password (and anyone else's) that you need to before terminating the connection.
Hope this helps.
Gary R.
Trending Topics: Storage Networking
