Upgrading a Cat4506 w/ Sup V
Answered Question
Mar 31st, 2010
I am trying to upgrade a 4506 w/ Sup V from cat4000-i9k91s-mz.122-20.EWA2.bin  to cat4500-entservicesk9-mz.122-50.SG6.bin
I currently have 512 MB of Ram and 56.50 MB of bootflash my current PROM is ROM: 12.1(20r)EW1
        Dagobah Revision 95, Swamp Revision 6
My conf-reg is set to 0x2101
Will my current PROM suffice or Do I have to do an PROM upgrade, and if so to what?
The reason for the upgrade in the 1st place is to add a  WS-X4548-GB-RJ45 V card.
Thanks in advance for any insight to this issue.
Mike
Correct Answer by Edison Ortiz about 6 years 9 months ago
You won't be able to get a PROM that matches your IOS.
Yes, the publication reports the recommended one but several iterations have been released since then.
PROM SGA4 is a viable candidate along with the intended IOS version
Edison
Since you are upgrading the IOS, you may as well upgrade the PROM to the recommended release.
Please refer to:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_5184.html#wp305142
Table 11
Edison
______
Each time you rate a CSC   discussion   we'll donate $1 to the American Red Cross Haiti fund up to a   maximum   donation of $10,000 USD.
https://supportforums.cisco.com/docs/DOC-8895
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Wed, 03/31/2010 - 13:54
Please refer to:
Table 11
Edison
______
Mike Mott Wed, 03/31/2010 - 14:54
Edison
Thank You for your reply .
I have to tell you I have looked at that document. My question regarding the prom upgrade is which one do I need
Given the IOS that I am going to install. The latest one that I see on the document that you asked me to take a look at is. 12.2(31r)SGA1
The download section shows 12.2(31r)SGA4 as the latest and I am installing cat4500-entservicesk9-mz.122-50.SG6.bin. So I would assume that the table was written at a certain time and the latest version did not come out until later. SO use the 12.2(31r)SGA4 ?
Mike
Correct Answer
Edison Ortiz Wed, 03/31/2010 - 14:55
Edison
Mike Mott Thu, 04/01/2010 - 09:56
Edison
Thank You for your time. I have rated both of your reponses. I am a good tech and have been for a very long time but I do so many things that it's hard to stay up on everything. I am extremely thankful that there are smart folks like yourself out there. Again my sincerest thanks.
Mike
