brain dead on ospf
w951duu
Just trying to bring up a new 3750 stack and route OSPF from our core, but it's been a while and I've mainly been doing BGP and EIGRP.. was hoping someone could help:
I'm seeing the neighbor relationship as full, but am not receiving any routes from the core router.  The core router gets it's OSPF routes from our other core router(s).. I think I should at least get networks defined in area 0??
3750 (CAR1) router IP: 10.14.1.2
CAR1.CF#sho ip ospf neigh
Neighbor ID     Pri   State           Dead Time   Address         Interface
64.38.14.148      1   FULL/DR         00:00:39    10.14.1.1       Port-channel1
core router (BDR1) IP 10.14.1.1
10.14.1.2         0   FULL/  -        00:00:39    10.14.1.2       Port-channel2
64.38.14.146      0   FULL/  -        00:00:38    10.13.1.1       GigabitEthernet2/1
74.200.240.5      0   FULL/  -        00:00:31    74.200.242.53   GigabitEthernet2/2
3750 OSPF CONFIG:
router ospf 600
log-adjacency-changes
redistribute connected subnets
passive-interface default
no passive-interface Port-channel1
network 10.13.1.2 0.0.0.0 area 0
network 10.13.1.0 0.0.0.255 area 0
network 10.14.1.0 0.0.0.0 area 0
network 10.14.1.0 0.0.0.3 area 0
network 64.38.14.148 0.0.0.0 area 0
network 74.200.193.4 0.0.0.3 area 0
network 74.200.242.54 0.0.0.0 area 0
Core OSPF CONFIG:
router ospf 600
nsf enforce global
redistribute static subnets route-map static-to-ospf
no passive-interface GigabitEthernet2/1
no passive-interface GigabitEthernet2/2
no passive-interface Port-channel2
Edison Ortiz
Based on the output, it seems you have mismatched network types.
While you can form adjacency with mismatched network types and identical OSPF timers, you won't be able to exchange LSA information.
It seems your 3750 stack is running the default broadcast mode while the Core is either running point-to-point or point-to-multipoint based on the output .. no DR is listed.
______
Each time you rate a CSC   discussion   we'll donate $1 to the American Red Cross Haiti fund up to a   maximum   donation of $10,000 USD.
https://supportforums.cisco.com/docs/DOC-8895
Edison Ortiz
______
Awesome!
That was it
Glad to be of help.
Please remember to rate helpful posts.
Edison
Thanks.. I rated the post!
