Question 'show ip bgp neig' and advertised routes
Answered Question
Mar 31st, 2010
I think I heard this before but I can't find the answer:
Imagine you have route-maps, prefix-lists etc filtering a given advertised BGP route.
Then you want to analyze how the advertised routes to a neighbor would look like without the effect of the aforementioned prefix-lists, route-maps, etc.
Is there any command to accomplish that?
To my understanding 'advertised-routes' should list the output of the actual advertised routes to a neighbor including filters (such as prefix-lists, route-maps).
R2#show ip bgp neig 10.2.2.47 ?
  advertised-routes  Display the routes advertised to a BGP neighbor
  dampened-routes    Display the dampened routes received from neighbor (eBGP
                     peers only)
  flap-statistics    Display flap statistics of the routes learned from
                     neighbor (eBGP peers only)
  paths              Display AS paths learned from neighbor
  received           Display information received from a BGP neighbor
  received-routes    Display the received routes from neighbor
  routes             Display routes learned from neighbor
  |                  Output modifiers
  <cr>
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
Hello Marlon,
sh ip bgp
if no filter is applied all valid BGP routes not learned by that neighbor would be advertised to it
so if x.x.x.x is the neighbor
sh ip bgp | exclude x.x.x.x
should give you a good approximation of you would send to x.x.x.x without any filter applied: all the local RIB
well actually only >* best paths are sent out
soa regular expression would be needed
sh ip bgp | include  *>
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Wed, 03/31/2010 - 15:24
  • Hall of Fame,
    Founding Member
Hello Marlon,
sh ip bgp
Hope to help
Giuseppe
