startup-config won't load
Mar 31st, 2010
I got ASA 5510 ver 8.2.  Every time when I cold boot the ASA the startup-config not load.  I have to get into the console and manually run the load command to startup.  What do I need to make it the startup-config automatic load?
Nelson
Jon Marshall Wed, 03/31/2010 - 16:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Nelson
Can you post a "sh version" from the firewall ? It sounds like your config register value may be wrong.
Jon
Jon Marshall Wed, 03/31/2010 - 17:20
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Nelson
Your config register is 0x0 at the moment. You should change it to 0x1 ie.
ASA# config-register 0x1
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
