03-31-2010 04:43 PM - edited 03-17-2019 09:58 PM
I think I already know the answer for this but I just wanted to make sure. We have 4 7985 phones and we are able to make point to point video calls but once we conference the video goes away and we only have audio. I know the VT Advantage software with the eyeball can do up to 3 or 4 video conferences but something is telling me that the 7985 can only do point to point video. Is that the case?
Anthony
Solved! Go to Solution.
03-31-2010 04:53 PM
7985 and VTA work the same way in this regard - they all just do point to point.
If you want multipoint, you need something extra to mix the streams - MeetingPlace Express could do it with the right license, and there are hardware options...
Aaron
Please rate helpful posts..
03-31-2010 04:53 PM
Aaron
