Win2003 64 bit IPSec remote access client?
Mar 31st, 2010
I want to connect my Windows 2003 R2 64-bit server to different remote networks via IPSec, the same way a remote user would log in with a Cisco VPN client. The problem is that I cannot find a 64-bit IPSec client (Cisco or 3rd party) that runs on 2003. Did anybody try this before and had it working?
Peter
Federico Coto F... Wed, 03/31/2010 - 18:44
Cisco intended to use the Anyconnect (SSL) client for the 64-bits OS now.
But, there is a BETA IPsec VPN client from Cisco available for 64-bit:
vpnclient-winx64-msi-5.0.07.0240-k9-BETA.exe
According to the release notes, it is only for Vista and Windows 7 (not for Windows 2003), but you might give it a try.
Federico.
