ASA5505 issues with SIP trunk.
Mar 31st, 2010
Hi All,
I have problem with our ASA which is driving me crazy. ITSP is sending calls using SIP to our Public address. The ASA is configured to port forward the traffic to internal voice gateway/CCM , however the ASA seem to discard the packets even thought I have permitted them in the inbound ACL’s.
SIP configuration from my ASA as below.
object-group network ITSP
network-object 135.216.160.11 255.255.255.255
network-object 135.216.160.7 255.255.255.255
network-object 135.216.160.12 255.255.255.255
network-object 135.216.160.13 255.255.255.255
network-object 135.216.160.14 255.255.255.255
access-list Inbound_traffic extended permit udp object-group ITSP host 203.161.121.130 eq sip log
static (inside,outside) udp 203.161.121.125 sip 192.168.12.251 sip netmask 255.255.255.255
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ils
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect tftp
  inspect http
  inspect pptp
class class_http
  inspect http
class SMTP
  priority
class http-mss
  set connection advanced-options mss-map
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
When I make call to the number directed to my public IP address from the ITSP I get the following message.
Mar 31 04:59:15 ASA5505 %ASA-6-607001: Pre-allocate SIP Via UDP secondary channel for outside:135.216.160.7/5060 to inside:192.168.12.251 from INVITE message
Mar 31 04:59:15 ASA5505 %ASA-6-607001: Pre-allocate SIP SIGNALLING UDP secondary channel for outside:135.216.160.7/5060 to inside:192.168.12.251 from 404 message
Mar 31 04:59:15 ASA5505 %ASA-6-607001: Pre-allocate SIP Via UDP secondary channel for outside:135.216.160.7/5060 to inside:192.168.12.251 from ACK message
Mar 31 04:59:50 ASA5505 %ASA-6-607001: Pre-allocate SIP Via UDP secondary channel for inside:135.216.160.7/5060 to outside:192.168.12.251 from INVITE message
Mar 31 04:59:54 ASA5505 %ASA-6-607001: Pre-allocate SIP SIGNALLING UDP secondary channel for outside:135.216.160.7/5060 to inside:192.168.12.251 from 200 message
Mar 31 05:03:19 ASA5505 %ASA-7-710005: UDP request discarded from 135.216.160.7/5060 to outside:203.161.121.125/5060
Mar 31 05:03:45 ASA5505 %ASA-7-710005: UDP request discarded from 135.216.160.7/5060 to outside:203.161.121.125/5060
Mar 31 05:03:46 ASA5505 %ASA-7-710005: UDP request discarded from 135.216.160.7/5060 to outside:203.161.121.125/5060
Any help will be much appreciated
Mohammed
Overall Rating: 3 (1 ratings)
Federico Coto F... Wed, 03/31/2010 - 11:10
You have a STATIC NAT statement redirecting SIP to IP 203.161.121.130
You also have an ACL allowing the traffic.
But the logs show the SIP (UDP 5060) attempting a connection to IP 203.161.121.125
These are the connections that are being denied, because there's no STATIC NAT for .125
Federico.
mnour401917_2 Wed, 03/31/2010 - 18:20
Hi Federico,
Thanks for the response. I have checked again and the NAT statement i included was the the wrong one. i have i have included the right statement now. tested again and still get same result.
when i do a packet tracer check against the applied policy, i see the Implicit rule denying the packet. Any idea?
Mohammed
Federico Coto F... Wed, 03/31/2010 - 18:37
So, now you have an entry in the ACL inbound_traffic permiting UDP port 5060 to 203.161.121.125 correct?
Is this entry above any other deny rule that might be blocking this traffic?
The reason I ask is because you mentioned that the Packet Tracer shows the implicit deny any any rule in the ACL denying the packet correct?
According to the Packet Tracer is the ACL inbound_traffic the one blocking the connection?
If so could you attach the output of the ''show run access-list inbound_traffic''?
Federico.
